Holley hi ram, injector hat, methanol
Old 06-22-2014, 06:20 AM
Torcha's Avatar
Default Holley hi ram, injector hat, methanol
Hey guys, building an aspirated 6 litre. Plan was methanol carbs on a holley hi ram but been doing a bit of reading and came up with a bit of a wacky idea for something different...
Efi hi ram with the blank top, modified to fit a bug catcher type injector hat. Tps on the hat.
Now for the stuff I'm not so sure on:
Injectors? What size injectors would I need to run straight methanol?
Ecu? Would I be able to use a factory ecu with hp tuners? Or would I have to run aftermarket?
Engine is an iron block with l98 (Aus spec l92) square port heads, will be around 12:1 comp, custom grind cam by Martin 243/263 627/632
Pretty new to injection, feel free to tell me if I'm missing anything, or completely mental. Cheers
Old 06-22-2014, 04:26 PM
Torcha's Avatar
Can anyone at least tell me if they've run meth with a stock ecu before?
Quick Reply: Holley hi ram, injector hat, methanol
