No fuel pressure, turbo car
Old 07-20-2014, 10:01 PM
topgun542's Avatar
Default No fuel pressure, turbo car
So got the car to crank and has oil pressure. getting fuel out of my fuel pressure regulator, just no pressure. if i prime my pump a few times it comes out in pretty good stream but takes a few key turns to get the fuel there. Im using a dual pump setup run off a hobbs switch. twin 255 walbaros. Any ideas on what it could be doing not letting the fuel get there fast enough and not getting pressure?
Old 07-21-2014, 07:17 AM
Old Geezer's Avatar
"Pretty good stream" means what?? 10 psi? Put a gauge on it.
Has the car run w/ the current set up, and this just happened?
Home made in tank?
In tank plumbing problems is where I'd start.
Old 07-21-2014, 06:56 PM
topgun542's Avatar
Home made in tank?
My gauge on my fpr reads 2psi... lol but its a good stream. it has not run, just been put together this year. its dual 255s
Old 07-22-2014, 08:04 AM
Old Geezer's Avatar
Like I suggested.. Look in the tank.
Old 07-23-2014, 11:23 PM
topgun542's Avatar
I was using the evap as a return.... didnt block off the tee after the filter.... lmao it works now hahahah
Quick Reply: No fuel pressure, turbo car
