Easiest injector upgrade for NA LS1?
I've done plenty of searching, but I'm still lost on what injectors to get. I'd like to get a solid ~400 hp out of my LS1 with H/C/I, and I figure I should upgrade the injectors now, while I have a tune that works I can mess with. I would like injectors that fit the LS1 rail/harness, have free data somewhere (or come with the correct data), and won't kill idle or emissions. Seems like I need around 35-40 lbs, I don't plan on FI or nitrous.
I think some of the Bosch ones fit, and I have found data for them as well, any more specific recommendations?
http://fuelinjectorconnection.com/sh...php?groupid=97
i run 36# FIC injectors, no complaints....i think there may be an LS1Tech member discount
OK, did more searching. I guess these FIC injectors are redrills (say some people on the internet), and they don't necessarily plug and play with just an IFR change. The question is whether the ID injectors work 2.5 times better or not.
My last car had Megasquirt, so I'm pretty familiar with what it's like to have no injector data at all - it always had a little trouble on cold starts, then ran fine under closed loop and at WOT. Still, it would be nice to do things more righter this time around...
you have to put all the data in. And if you buy "new" injectors, they aren't re-drills. You can't simply JUST put the IFR in with any injector change....I mean you can...but its not right.
They have all the data, call them.
Thanks guys, seems like with correct data the FIC injectors work fine, agrees Google. This should be an adventure, the amount of controversy surrounding LS injector stuff is crazy.
Buick/ASA injectors are plentiful and cheap. HP repository has an ASA tune for the data
I know first hand it works. These are plug and play.
P\N 0280155811 Alldata lists P\N as 24508208
BONNEVILLE 96-00 Fuel Injector; (6-231, 3.8L), w/supercharger
BONNEVILLE 01-03 Fuel Injector; (3.8L), w/supercharger
EIGHTY EIGHT 96-99 Fuel Injector; (6-231, 3.8L), w/supercharger
GRAND PRIX 97-99 Fuel Injector; 6-231 (3.8L), w/supercharger
GRAND PRIX 00-03 Fuel Injector; 3.8L, w/supercharger
PARK AVENUE 96-03 Fuel Injector; w/supercharger
REGAL 97-03 Fuel Injector; (6-231, 3.8L), w/supercharger
RIVIERA 96-97 Fuel Injector; (6-231, 3.8L), w/supercharger
RIVIERA 98-99 Fuel Injector; (6-231, 3.8L)
Should be the same injector thru '05 for the L67
Greg Bannish has an interesting read on resized injectors see pdf
