Questions on Super Victor Fuel Rails
Old 08-03-2014, 05:39 PM
Undying TA's Avatar
Default Questions on Super Victor Fuel Rails
I currently have everything ready to go on my super vic, but I have FAST fuel rails and racetronic injectors. Obviously the brackets don't line up and I'm debating making my own for the FAST rails to work on the super vic, but I'm curious if for the $110 if the Edelbrock fuel rails will work with my current injectors and the brackets that came with my super vic. If I have to make a custom bracket for the Edelbrock rails that is fine too (making taller ones because as it sits the rails are too tall for the stands). Any insight is much appreciated, and if this has already been talked about, I can't find it so if you could post the link I will cower in the corner with my tail between my legs, being forever grateful. Thank you in advance
Old 08-04-2014, 07:15 PM
Undying TA's Avatar
Anyone? Have any insight into the Edelbrock fuel rails with different injectors (not bosch).
Old 08-05-2014, 04:05 PM
Gray86hatch's Avatar
What injectors are you using. The edelbrock is set up for ev1 length
It would be best to use the edelbrock. Rails
Tim
Tim
Old 08-06-2014, 05:18 AM
Undying TA's Avatar
I'm using these injectors http://www.ws6project.com/user_stor/...flow-matched-/
Changing to the Edelbrock rails won't be an issue, I'm more worried about the injectors being a proper fit, because they have less than 100 miles on them and only 5 dyno pulls
Old 08-06-2014, 11:58 PM
Dmoney's Avatar
It will work. I'm using the Super Vic, Edelbrock rails and Racetronix 42lb injectors.........
Old 08-07-2014, 05:42 AM
Undying TA's Avatar
Thank you for the info, I ordered the rails yesterday. Appreciate the insight!
Old 08-07-2014, 07:22 AM
red_00z28's Avatar
Just a heads up. Get a 3/8 NPT tap and chase the threads on the rails. I wrecked a fitting last night.
Old 08-07-2014, 01:32 PM
Undying TA's Avatar
Thanks for the heads up, I'm pretty sure I have one in the tool box but I will have to see. Hoping they come tomorrow so I can get this thing back on the road for the first time in a couple years
Old 08-08-2014, 01:07 AM
8 Second Truck Club
Blown06's Avatar
Definitely do this. I think Edelbrock cuts their threads with a chisel.
Quick Reply: Questions on Super Victor Fuel Rails
