Fuel Bucket/AN lines
Here's the setup from a tank I bought....
It looks like -10 or -12 feed with a tube going into the bucket, and a -8 on the return. Looks like it retains the connector for the fuel level. Will be running a turbo setup on E85, external Magnafuel 4303 pump. Is this setup ok? Is that feed fitting ok to send e85? Thanks
Yeah I fond them and ordered last week, thanks. I ordered the 644003 with the plastic clip like the op has but I guess they were packaged wrong and they sent me the threaded one... should still work.
OP, those fittings will be fine with E85, and a -10 feed is plenty big enough assuming you don't plan on making over 1000ish hp. Out of curiosity, why didn't you just put a bulkhead fitting on the tank for the feed?
