Ly6 ecm and wiring harness options
Hello everyone I just bought a ly6 out of a 08 express van came with no wireing or ecm. So I was wondering what would be the easiest/ most cost effective way to get this car running?
Came with DBW throttle body, looking to run boost in the future.
Just looking for if I should convert it back to the 24x relictor ring set up and old ls1 ecm style or go with the new e38 or e68 ecm cuz it's that much better and cost effective? Just looking for the advantages or disadvantages of going either way? Any help is appreciated
I was thinking about going with the e38 ecm and wiring seems like it would be around $1000 with those two Items plus more with tuning software. Also from what I read that ecm will not sapport a Drive By Cable throttle body wich is about half that of an aftermarket DBW throttle body.
So I was looking at the megasquirt 3 pro and it seems to be around the same cost or less with software. I also see you can run to wide band O2 sensors with it and DBC.
So if any one has any experience with the newer megasquirt 3 set up preferable not the obsolete ms1-ms2 versions wich are very different and less capable.
Any help would be much appreciated
This is what I'm looking at getting for the ecm and harness
http://www.diyautotune.com/catalog/ms3pro-standalone-ecu-with-839-wiring-harness-p-538.html
