1998 fuel sender
Old 10-30-2014, 12:55 PM
63stingray's Avatar
Default 1998 fuel sender
Okay guys here is my scenario. Im LS1 swapping my 1996 z28. My car no longer has the factory fuel sender. I have a 1998 trans am, so Im considering swapping the entire fuel tank assembly into my car. I want my stock fuel gauge to work properly. I know the LT1 sender is 0-90ohms, but i also know that most if not all LS1s are like 30-270? I read somewhere that the 1998 LS1s are still 0-90 ohms, is this correct? If so, it should make the swap very simple. The reason I want to swap is because I already have a dual pump LS1 fuel pump set up that i would prefer to use rather than buy another LT1 pump assembly and modify that one. If anyone has any info i would be much appreciated
Old 10-30-2014, 09:53 PM
UNmolestedTA's Avatar
I think you are correct. Read a thread on ls1.com a while back on this.
Old 11-01-2014, 07:48 AM
Ollie8974's Avatar
This is the part number for the 0-90 ohm fuel level sender
for the 4th gen fuel pump module.
SK 1083
GM 25319676
Link to Amazon
http://www.amazon.com/s/ref=nb_sb_no...ds=GM+25319676
Quick Reply: 1998 fuel sender
