single turbo ls3 c6 corvette what fuel system
Old 11-04-2014, 02:25 PM
kpt
kpt's Avatar
Default single turbo ls3 c6 corvette what fuel system
I'm building a stock ls3 single turbo corvette with a goal of 700-750whp and latter on I want to make 1500whp what fuel system should I run pump,injectors,lines ect. I would like the system to be able to run e85 also.
Old 11-08-2014, 03:31 PM
ABMTex2007's Avatar
A dual 255 fuel pumps and 95lb injectors and stock lines is fine for 850rwhp on boost and 93.
For 1500 i assume c16/109 a regulated return system with -12 and a -10 return is ample.
Old 01-09-2015, 10:25 AM
LSxG35's Avatar
Look into the FORE innovations setup. You will need a lot more than 2 255s for that kind of power on E85. Im currently on a walbro 450 e85 which will probably run out about 650 give or take. Id1000s will get the job done for now, but if youre serious about 1500whp you will need at least ID2000s.
Old 01-09-2015, 10:55 AM
IronBlocked's Avatar
Dual-Triple walbro 450s
Old 01-09-2015, 09:21 PM
kpt
kpt's Avatar
is there anywere I can get a triple hanger just the hanger with no pumps? or I was thinking about 2 044 or 2 welbro 450lph
Old 01-09-2015, 11:06 PM
I dunno about the triple hanger, but you can get away with 2 450s on the stock hanger, I don't think you're gonna need any more, and if you do, there's always the magnafuel stuff
https://ls1tech.com/forums/fueling-i...g-install.html
https://ls1tech.com/forums/fueling-i...-tutorial.html
Old 01-10-2015, 10:07 AM
blackonblacksls's Avatar
Fore makes one.
Can do 1 465 and 2 aem e85s
Old 01-12-2015, 08:27 PM
kpt
kpt's Avatar
thanks for the info guys and link
Quick Reply: single turbo ls3 c6 corvette what fuel system
