aeromotive fpr - WILL -go past 40 psi NOW
Update 12/31°°°°°°°°°°°°°°°°°°°°°°first thanks for the advice guys! It was a cracked pick up tube and Shitty plumbing in the tank...
New pumps took care of my problem! Im Now at 60+ psi
ALSO my cold start issue is gone! Wierd how a cracked tube can make it warm up slow...??
Me and a buddy just got back from its first beat run...and OMG , amazing!!! I def recommend these pumps to anyone looking to upgrade!
^ UPDATE ^ see pics below
So I'm having trouble getting the fuel pressure past 4"0 base, and it will go down as low as 20 by adjusting it which is weird since it's only suppose to adjust between 40_75.. Also it drops pressure under boost instead of gaining. And the second I turn off key it drops to zero,. Pumps are 3 walbro 255, aeromotive boost reference, the silver block one with read hat, 40-75 psi. On the right end of rail,
opend it up and the diaphragm is ok. I hooked up a brand new tester gauge and same problems so I know it's not ny gauge. ..
Please help
UPDATE , the tester gauge was at 45 psi when I fired it up a minute ago and at the same setting late-night was around 38 psi, (I havnt touched it since) so why's it jumping around? Is there a leak somwere at the pumps maybe?
Also it cold starts usually and today it fired right up and went around the block fine..(usually it falls on its face unless you warm it up for 5 minutes. I'm confused on what else it can be.
I had my car tuned, so is there anything in the tune that could limit fuel presure or not?
Please help
If I do pinch the line, if the pressure raises its a bad fpr but if it doesn't change than I'm not getting anymore than 40 psi from the pumps? Correct? , and it drops psi instead of gaining.
You have a leak bleeding pressure somewhere. If you can't see/smell fuel anywhere it's probably with your pumps like already mentioned. How do you have the 3 pumps set up? Hobbs switch to turn them on? Running constantly?
All on, I'm waiting on the new dual phantom, but I won't have it for a week it so.
Bump anybody? Everytime there's a thread on something help full than ppl don't respond with any little tips, but when it's a pointless thread that has nothing to do with cars than ppl reply all day, I'm confused is this ls1tech or facebook?
Already talked to mat at aeromotive and he had me look over the diaphragm and spring when I was on phone with him and there's nothing wrong with the regulator, other than the diaphragm and spring there's nothing that goes bad,,it's just a aluminum housing.
So after that is when I am having this problem,
For all I know it's just floating around in there. Not really but risk how he set it up,
And the car went strait on a trailer from wi to CO, got here and noticed the problems, low psi, sputters around corners, after half tank it runs like ****,
Now of course I can't get Dave to answer or anything, so maybe he fucked something up? That's why he won't help?
I already have the new dual phantom pump on its way but I want to try and find the problem anyway, I fear it may not be the reason for low psi, but I'm still upgrading either way,
Was my first try was the fpr
So that's where I'm at, I'm waiting on pump and a new diaphragm for ***** and giggles, also orderd all black fuel fittings, since I now have summit and figured may as well get nice fittings, these summits tighten like ****.
I was just hoping in the meantime I could exclude any other possibility, ,, ie a leak, or hoping somebody has had the same problem and found the problem, fuel pressure can't be limited in the tune can it, ie 3 bar fuel pressure, which would be 14.5 x3= 43.5psi. ??
"And the car went strait on a trailer from wi to CO, got here and noticed the problems, low psi, sputters around corners, after half tank it runs like ****,.
Bingo... U may have a winnah. Pretty obvious Dave has something phucked up, in the tank.
A suggestion: when dealing w/ future issues, post all the info about the car, and you may get more responses. [And, won't have to go to FB!]
Fuel pressure can't be limited in the tune can it?
I now have summit fittings, I'm also swapping them for aeromotive, these summit ones suck,
Like I said I'm eliminating all possibilities where it could bleed off ,plus the summit ones kook like ****, I'm doin all black fittings,it's almost time to dress up under the hood any way
