Simple fuel question
Old 12-18-2014, 01:04 PM
Taxman20's Avatar
Default Simple fuel question
I am swapping an LQ4 into an S10. Not using the stock tank or pump, so I am installing a fuel cell and need a good external pump. I was told 55psi is what the fuel injectors need, so do I get a pump that has 60-65 psi so that is always has enough pressure? The rail has the inline regulator. Engine right now is stock with headers and it may get a cam swap so I don't need anything special for high hp right now. That comes later with the next build.
Old 12-18-2014, 04:50 PM
76larkman's Avatar
Not totally sure but I think you can run corvette pump and filter combo as its regulated 58psi. thats what I see on here alot.
Old 12-18-2014, 05:21 PM
Fullen's Avatar
Yes. As long as you have a regulator in the line you'll be fine.
Old 12-18-2014, 06:15 PM
Taxman20's Avatar
Ok. Thanks for the help.
Quick Reply: Simple fuel question
