Aftermarket Rail Installation Question
Old 01-06-2015, 02:31 AM
GreenS-10's Avatar
Default Aftermarket Rail Installation Question
Upgrading the rails on the wifes 2000 camaro. Since the regulator is in the tank, can I just go from the stock rail push on connection to the aftermarket rail and have it work correctly? I didn't want to have to re-engineer the fuel system to use the upgraded rails.
Old 01-06-2015, 02:39 AM
GreenS-10's Avatar
Using something like this to the aftermarket rails.
Old 01-06-2015, 01:43 PM
jclayc's Avatar
I used http://www.summitracing.com/parts/RUS-640940/ to go from the factory 3/8 fuel line to a -6 AN fitting on my LS6
Old 01-06-2015, 04:13 PM
GreenS-10's Avatar
Did it work fine with no issues at the normal pressure?
Old 01-07-2015, 10:42 AM
jclayc's Avatar
Yes, worked fine when I had an OEM setup and it works well now with an aftermarket pump, FAST fuel rails, fuel pressure regulator, etc.
(With the OEM rails, I converted the under-hood fuel line to a -6 line. That required I use RUS-640940 plus http://www.summitracing.com/parts/RUS-640850/ on the rail's input.)
Old 01-08-2015, 09:05 AM
Ollie8974's Avatar
Do not use the fittings with the nylon lock. They are known to fail under pressure.
Use the style with the threaded collar.
http://www.summitracing.com/search?S...EFI%20fittings
Attached Thumbnails Aftermarket Rail Installation Question-new-style-screw-lock.jpg   Aftermarket Rail Installation Question-step-1-russell-efi.jpg   Aftermarket Rail Installation Question-step-2-russell-efi.jpg   Aftermarket Rail Installation Question-step-3-russell-efi.jpg
Quick Reply: Aftermarket Rail Installation Question
