running fuel lines, will this work ok?
redoing fuel system and my plan is to do this, im not 100% sure if it will work so thats why im asking, if i left something out or im missing something, why im asking lol.
i plan on running a -8 adapter off my pump assembly feed, running -8 line with filter to driver side of FAST fuel rail, use there -8 cross over on the front to pass side rail, then run a -8 return line off pass side rail back to return port on pump assembly, keeping factory fuel pressure regulator in tank, currently have a aeromotive 340lph pump in tank.
will this keep the 65psi FP ive had or at least 60-70psi? or will it just flow through the rail and dump back into tank and have minimal to no pressure? thanks!
so it has to return before it gets to the rails? my understanding is the stock line goes through the filter then T's off, one end goes to the rails other back to the tank as the return correct?
would i be able to remake it just like the factory lines but in -8 and be fine?
have -8 off feed from pump, through a filter, then a T in the line, one goes to fuel rails, other goes back to return?
o ok, havnt looked at them in awhile, was thinking Fbodys had them in the pump assembly and trucks had them on the rails, hmmm probably just fork it out at this point and get a boost reference FPR i guess lol
guess i can ask this while in here then, say i ditch both factory FPRs, i i plumb it like i said in first post, could i put an Aeromotive 13110 boost reference FPR on the last fuel rail/between the back of the pass side rail and the return line, so the rails feed into the regulator and then the return line comes out of the FPR and back to tank, that would be the correct way to run it yes?
The better way to do it would be to run your feed to a Y fitting right before the back of the rails. From the Y fitting go to each rail. Mount the regulator on front of one of the rails. Crossover from the front of the other rail to the regulator, then run your return line from the regulator to your tank.
Look at pic in these instructions.
http://fuelab.com/wp-content/uploads...tructions1.pdf
I'd take power recommendations with a grain of salt. Everyone's fuel system is different, so a Y may work in someone's 1500hp motor and fail in someone's 800hp motor. Do you need it? Who really knows. It's probably worth the extra $20 in fittings to do it right.
