ls3 injectors in ls1
Old 02-10-2015, 09:33 PM
LsPrideOrDie's Avatar
Default ls3 injectors in ls1
So i tried searching but cant find a straight answer. I just ordered FAST 39lb injectors, LS3 style. What else do i need to get to run these on my 2002 Camaro?
Old 02-12-2015, 11:14 AM
iliveonnitro's Avatar
You'll need fuel injector spacers/adapters and an LS3 injector harness. I think FAST sells them both.
Old 02-12-2015, 11:36 AM
Well i talked to a few other guys, they said i need spacers and adapters. i already bought them. I wouldnt need the ls3 hardness since the apaters plug the ls1 style plugin into an ls3. Correct?
Old 02-13-2015, 09:21 AM
If you have the adapters, correct.
Old 02-13-2015, 09:23 AM
Okay awesome. Thank you!
Old 02-13-2015, 10:21 AM
redbird555's Avatar
dont get the fast adapters. they go on the bottom of the injector and can effect flow pattern get a set of the fic ones that go on top of the injectors
Old 02-13-2015, 10:29 AM
http://www.xplosiveperformance.com/thumbnail.asp?file=assets/images/cb16b363-b5d8-4e0a-8b99-ba26fc5f7cdc-420.jpg&maxx=300&maxy=0
If you go to that link, i got the purple ones all the way to the right. Those the good ones?
Old 02-09-2019, 08:42 PM
michakaveli's Avatar
This work better.... says "top hat" ... understanding these go on top?
LS3 TO LS1 INJECTOR INSTALL KIT
Quick Reply: ls3 injectors in ls1
