Custom fuel System
Custom fuel System
ive got a 99 TA that Id like to build a custom fuel system for, I'm in the process of building a turbo 5.3 to put in it. Making around 900whp. Could someone talk me through or post a diagram on how I'd need to plumb this in?
Twin walbro 255s,
-8 supply
-6 return
Fuel pressure regulator
Nasty performance rails,
96# injectors
Stock fuel tank
Any info is greatly appreciated
Thanks!
Twin walbro 255s,
-8 supply
-6 return
96# injectors
Stock fuel tank
Thanks!
Like this, except you'll want to Y your two fuel pumps: http://www.magnafuel.com/products/kits/MP-4813.htm
Here's a good link of the process: http://mustangforums.com/forum/4-6l-...l-systems.html
I'm doing basically your same setup with same hp goals (slightly different parts). Your -8 supply/-6 return should be enough. With that being said, magnaflow recommended -12 from the tank to the first fuel filter, -10 to the rails, -8 return. The reason, I was told, is to keep volume up to the rails when the demand increases (and that it couldn't hurt).
I have an extra (brand new) walbro 255 if you're interested in saving a few $. What injectors are you going with?
Use the Y adapter in link nitro posted.
Hunt down the RIGHT GRADE wires that have gasoline or alcohol compliant insulation. The cheap wire insulation will eventually melt in the tank. Can't remember off-hand but I think mightymouse's twin tank how-to has the right p/n.
Your plan will work, I would suggest routing but I have to re-do mine after suspension and exhaust changed.
Thanks for the responses guys. How would I pipe this in to my stock fuel tank? Just run -8 to the nipple off the top of my drop in assembly with a hose clamp?
Purchase the fittings with the U shaped screw on lock.
Do not use the type with the plastic lock they are known to blow off under pressure.
http://www.summitracing.com/search?S...EFI%20fittings
And also what adapter would I need to go from -8 an hose to these fuel rails?
http://www.summitracing.com/parts/hly-534-210/overview/
The two fittings shown are 3/8 x -6 AN
The center is 15/16 x -6 AN.
The part numbers are listed in the link.
Total fuel system:
dual walbro hotwired with in-tank Y fitting to merge both pumps to stock feed fitting
stock tank barb outlet to -8 adapter fitting
-8 feed from tank with inline filter up to engine bay
-8 feed to y fitting (-8 to dual -6)
dual -6 feed to both rails
dual -6 from rails to three way -6 Y fitting
-6 Y outlet to -6 boost referenced fpr
finally -6 return to stock tank return with adapter
Use these Russell fittings.
