Fuel pressure regulator plumbing
Old 02-18-2015, 11:23 AM
tommycompton's Avatar
Default Fuel pressure regulator plumbing
Time to do my fuel system upgrade, then its finally tune time. This is for a supercharger build, with a areomotive 340 with a kb boost a pump. I did buy all the hardware to add a second pump if needed.
My question is on plumbing in the fuel pressure regulator, I currently have a Y feed into the rails, and was wondering about keeping it that way
instead of this, which is the way I assume most do it.
This is a Y fed set up....
But to keep things neat and clean, I was thinking of plumbing it like this,
with a tee off one end of the rails with one line going to the regulator.
Does anybody see a problem with plumbing it this way as opposed to the other methods? I am hoping to get even flow and pressure to all teh injectors, but does it not matter as much when a fpr is added after the rails?
Also for a boosted application would It be best to use the boost/vaccum line on the FPR? or is that something you just tune around? seeing as its not really a stand alone system.
Old 02-19-2015, 10:41 AM
iliveonnitro's Avatar
#2 and #3 are essentially the same. If you have issues running #3, you have bigger problems than the lines not being the same exact length.
Old 02-20-2015, 07:30 AM
That's what I was thinking. I figure the fuel will flow to where the pressure is being released ie. the return at the fpr.
Quick Reply: Fuel pressure regulator plumbing
