Where do I install my fuel pressure sensor???
Old 02-25-2015, 08:53 PM
Fier23's Avatar
Default Where do I install my fuel pressure sensor???
I am installing a glow shift fuel pressure gauge. Where do I install the sensor? Can I install in at the end of the fuel rail, thought that was where I would have to install it.
Old 02-26-2015, 03:20 PM
stevieturbo's Avatar
As close to the rails or injectors as possible.
Or if you have a return style FPR, just install it there, almost all have a port for it.
Old 02-26-2015, 05:07 PM
Fier23's Avatar
I bought this adapter. I believe it's what I need to attach to the end of the fuel rail.
http://www.glowshiftdirect.com/4-an-...l-adapter.aspx
Old 02-26-2015, 05:27 PM
76larkman's Avatar
Looks like that will screw onto the nipple fitting on rail that usually has a screw off cap. I would think you can put that directly to rail fitting.
Old 03-02-2015, 09:01 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
Do not install the sender on the rail. This is what happened to me and almost caused a big fire:
Run a short length of proper An line and have the sender mounted somewhere else.
Andrew
Old 03-03-2015, 03:12 AM
I'd never hand any weight off the rails or fittings like that. The way people mount FPR's directly to the rails also worries me
Always best to remote mount anything with weight on a flexible line
Old 03-03-2015, 04:52 AM
maroonls1z's Avatar
I am using a mount that Mighty Mouse makes that attaches it to your brake booster. I really like it because it's it of the way and a solid mount
Old 03-03-2015, 10:05 PM
WVhuggerSS's Avatar
Do you have a link or picture to that part?
Old 03-04-2015, 07:12 AM
Realcanuk's Avatar
http://www.mightymousesolutions.com/...ooster-bracket
Old 03-04-2015, 09:56 AM
a-low's Avatar
Mm bracket , glowshift sender
Old 03-04-2015, 06:41 PM
WVhuggerSS's Avatar
Thanks for the link and picture, thats a good looking setup right there.
Old 03-06-2015, 09:39 AM
MIGHTYMOUSE's Avatar
nice powdercoat job!
Quick Reply: Where do I install my fuel pressure sensor???
