Prolly a stupid question, but TB sizing?
If I have a stock LS3 (430hp), but put on a 101mm throttle body, what will happen? Will the engine bog on take off or run lean in some way? Technically, the computer should be able to compensate within reason. What about WOT?
This is a cable operated set-up using a Holley HP.
Andrew
