Fuel Injector help
Old 03-15-2015, 06:55 PM
Cleb98's Avatar
Default Fuel Injector help
Hey guys, I have an unknown set of truck injectors that I was planning on using for my 5.3 swap. I have these laying around so I would like to use them if possible and avoid spending $100 or so on ls1 injectors. I am using an f body harness that has the injector plugs for the ls1 injector. I originally thought it would be a very straight forward connector swap. When I looked closer at the truck injector connectors the two wires for each plug are a different color combination for each injector. How can I successfully swap these connectors for the ls1 connectors and make sure the wires are swapped over correctly? Sorry if that sounds a little confusing, hopefully the pictures below help. They are of the truck connector next to the ls1 connector and then all of the different wire color combinations. Any input would be great, again I'm trying to use these if its possible for them to work
Attached Thumbnails Fuel Injector help-img_0126.jpg   Fuel Injector help-img_0127-2.jpg   Fuel Injector help-img_0128.jpg   Fuel Injector help-img_0129.jpg   Fuel Injector help-img_0131.jpg
Old 03-15-2015, 10:09 PM
slocaddy's Avatar
It doesn't matter witch colors you put together, I just did mine not to long ago After alot of searching.
Old 03-15-2015, 10:15 PM
Cleb98's Avatar
Awesome. So how will i know what wires to connect? Sorry if this sounds stupid, just trying to figure out how i will get the orientation correct considering there isn't a consistent wire color
Old 03-15-2015, 11:24 PM
slocaddy's Avatar
Colors don't matter, there's no polarity (+/-) to worry about keeping straight, just snip and reconnect, repeat 16 times, done.
Old 03-15-2015, 11:58 PM
Cleb98's Avatar
Awesome that helps a lot! Thanks
Quick Reply: Fuel Injector help
