Squash Performance: Need help finding correct sending unit
I decided to try and go with a Squash Performance dual in tank setup and want to know what sending unit I need to order with it. The setup will be going into a 1998 TA. I tried measuring the resistance when the arm is all the way up and down.
Max Ohm: ~196
Min Ohm: ~41
Here are my options on their site:
New Level Sensor
- I'll reuse my stock one
- 99-02 stock replacement (33-240 OHM)
- 0-90 OHM for swapping
http://www.squashperformance.com/199...stem_p_44.html
Also looks like I am going to need to source a 99-02 Plastic tank to drop it into.
Can anyone shed some light on the subject?
Max Ohm: ~196
Min Ohm: ~41
New Level Sensor
I just placed the exact same order, I used the 99 -02 stock replacement because my car is a 2000, don't know about the 98 model. I can't wait to receive my set up, its a complete set up for my upcoming turbo build. post pictures when you get your stuff.
what pumps are you going with? whats your goals and set up?
