Old gas
Old gas
I have a tank full of gas that's been sealed up in the garage for a while and was unsure if it'd be ok to just run out or would I need to drain it. Color has changed slightly and it still smells like gas, though not quite as small as some dress that I have.
Just looking to see why kind of experience you guys have had with aging fuel.
Old
Fresh
Old
Fresh
I work at a salvage yard and burn the gas we pull from all the cars we get in my crappy daily driver, It looks a lot worse than that and doesn't always smell that great but it works and it's free lol. If it still smells good I would mix it with some fresh gas and use it up. Todays gas lasts a lot longer than it used to.
Appreciate the feedback. My thinking before seeing it was that if it looked about the way it is ten I would just run with it. Worst case, I drain 1/2 the tank and refill with fresh. Seen pics of the really old and nasty looking stuff. So I kinda had an idea of what I definitely would not use.
glad you asked! These injectors had sat for about 2 years with fuel in the rail and the algae was florishing!
About a week after exposer to the air, it's all dried up
Storing gas typically requires you to put in an additive and fill the tank to the brim so very little air can touch the gas.
If you had a full tank, you're probably okay if it's only been a winter. It largely depends how much air it was exposed to, and for how long. If you drain it from the bottom, you're only draining the (potentially) good part of the gas.
Holy green gunk!! Glad you showed me that. Actually got me thinking about pulling the injectors and having them cleaned. Car has 140k miles and I've only had it for 20k of those.
Tank was all but completely full when it was parked. Wish I would've completely topped it off before. Read that some have tossed in a can of Seafoam to "refresh" a tank of older gas. May give that a try instead of dumping half the tank and then refilling. Especially if I'm only dumping the better part of the gas out
A tank of gas is cheap insurance. If you have the means to drain it now, do it. If not, try out what you have before draining it.
