ebay (clone) bosch 044???
Hi guys.
Need some input on these pumps. Cant find much info. Its for a turbo 5.3l want to use one running en second one turn on at boost. Any info will be ok.
Yea I know this is a 2015 post. But I wanted to put the info out there. No one uses these pumps and they aren't that bad.
Always best to do your own tests and make your own conclusions IMO. To many people spout nonsense and have never had any experience with the "CHEAP CHINA JUNK". I tend not to listen to these types.
I paid a guy on here to test them... He sort of did, then disappeared with my pumps and fittings he was suppose to send back and never got back the final results. They actually did pretty well for a $23 pump! Not as good as a true 044, but impressive.
At 13.5v and 70psi they put out 5gpm VS an 044 at 7gpm. Also interesting they had a great pressure VS flow and did not drop significantly like most walbro style pumps. 3 pumps were set at 40 and then 100psi for 1 hour with no overheating or major problems. All 3 pumps were tested and 3% of each other in that hour time on his flow meters.
T-fiddler ran 2 of these pumps on his twin turbo build and was going 126+ in the 1/8th. So not bad for $46 worth of pump. I had planned to use 2 of them in parallel as a "booster" Then cruise around on an AEM400. So for $46 I'd have another 600g/hr of fuel on tap. And the pumps are only working while in boost, reliability isn't a huge issue.
To sum up above... 2 $23 knock offs in parallel flow about what 1 AEM400 flows ($150 pump).
