Need some help with my dual pumps
I've been looking through writes up after write up and can't really find exactly what I'm doing. I bought the dual 340 racetronix kit. Here's what information I need.....
How are you cutting the stock bucket to fit and where are you guys grounding the pump as I don't see how the wire would be able to go through the top of the hat?
I bought a -8 feed line and -6 return lines. From what I've seen, they cap the left outlet (if the openings are facing you) use the center outlet for the return, and use the right outlet for the feed? Am I correct on this bc I see people doing this all kinds of ways.
Any info on the dual racetronix kit would be great as they don't supply instructions. Thanks guys
