replacement of injector o-rings
Hey guys I have a nuisance. Prior to start up of ls swap in my truck I noticed I had a fuel leak. I checked my rails on my pro flo xt intake n noticed it came from the pipe fittings due to the threads being stripped so I had em tapped. Not only that I had leaks coming from my injectors. So I replaced the rings. My thing is that the original lower rings fit snug and when I replaced with the new ones they're not as wide. I mean they seem to be loose. The top ones are fine. I have 34# injectors that came with the ls2 ev6 connector. Does someone know the exact o-rings I need to get. Thanks
