Using Factory Feed Line for Return. What to do with stock filter
Ok so I am running a new -8 feed line for my turbo setup, and I am using my factory feed line for a return. What do I do with the factory fuel filter? I'm assuming I can't leave it in the line.
put the filter in a vise then drill a hole in the filter from the threaded side and clean it out really good !
Im in the process of doing the same thing but using the stock return port on the top of the fuel hat (that way you don't have to worry about the fuel filter being in the way). Pulled out all the stock fuel line and evap line and running -8 for feed and -6 for return. Russell makes fittings for the fuel port to -8 and -6 for return.
Can you send me a picture of this setup? Another guy said he ran a stock filter, so that's how I set it up, but if it is going to cause false readings then I don't want to do that.
