Anybody help me with this racetronics hot wire kit?
Old 04-27-2015, 12:24 PM
WVhuggerSS's Avatar
Default Anybody help me with this racetronics hot wire kit?
What's the deal here to why the one plug isn't the same? I put the supplied bulkhead connector on to make the one side match but this other one doesn't? Its frustrating trying to get ahold of racetronics to ask what I need so anybody know? FPA-001B pump assembly with FPWH-017 harness.
Old 04-27-2015, 12:51 PM
ss1
ss1's Avatar
I might be wrong here, but I believe you plug your stock power feed/fuel level sensor connector into the square black connector pictured. The flat black connector plugs into the bulkhead connector you swapped out. The black pressure sensor should use the same connector that was connected to it.
Old 04-27-2015, 01:25 PM
WVhuggerSS's Avatar
So basically like this? Why I couldn't figure that out last night I have no clue, I guess I juss got confused. Thanks for the help.
Old 04-27-2015, 01:56 PM
ss1
ss1's Avatar
Looks right to me! That way it still sends the signal to your fuel gauge through the original cable using the two purple wires. I believe the other two original power wires control the relay that now feeds your fuel pump with the larger red/black wires.
Quick Reply: Anybody help me with this racetronics hot wire kit?
