I'm kind of regretting this now. Need help
So I'm doing a twin pump set up and to I cut the bottom off of the bucket.... Was this a bad idea? I've seen others do it but after I did, I cringed . If it's bad I'll buy a new bucket
Depends on what you mean by bad. IMHO yes it's bad. Now you run the risk of fuel starving the pumps of fuel if the tank gets too low and/or you accelerate too hard.
The only reason why I thought it was fine at the moment was because you would have to cut two holes regardless to let the bottom of each pump stick out. So that's why I thought it didn't matter. But the reasons you said it was bad was exactly what I was thinking and why I posted this
