Fuel system conversion
Hi folks,
I've received my LQ9 today. Overall it's in decent shape, now the quest begins to put this into my car. One of the things I need to worry about right now is the fuel system. I basically have two options:
1) Keep the current return system on the LQ9 and redo all lines/tank/pump/filter
2) Convert to returnless and redo one line/tank/pump/filter
I'm looking at tanksinc.com for my fuel components, and looks like maintaining the return system is a bit more expensive, mostly because the hose is so damn pricey (I need about 45ft of it for both lines). Seems like a returnless rail goes for ~60-ish? Is that correct?
Any pros/cons of running either system? Or just look at the bottom line ($$) and go with what costs less?
Thanks,
Dante
Thanks,
Dante
Use the nylon tubing like the factory does, so much easier & cheaper than dealing with hardline or AN lines & fittings https://ls1tech.com/forums/fueling-i...ttachment.html
Wow, hadn't seen that type of line before. I still have the original hard lines from my car (a '72 fuel line) and I've read that using it for EFI is a no-no. Anyway, do these nylon lines leak vapor? This looks like a great and inexpensive solution.
Yeah that sounds like a good approach. I'd have to flip the rails on my intake though, as the lines come out on the passenger side, near the front.
