suggest injector for cam only 400 hp?
A matched set of ls3s is all you'll ever need then. You can do pull offs, but I like cleaned and flowed.
We have a set of FAST 36lbers that will work great for a great price.
The ls3s wont work unless you wanna spend alot more money to make em work.
Pm me and ill get you set up!
Ok, last reply. Getting new injectors at this point doesn't make sense.
1. He will need a new tune which he will need when he does heads. Why pay for a tune twice?
2. Unless he is truly at 98% duty cycle, it's a waste of money imo.
Sorry, just trying to save the OP money
Because honestly anything over 90% on an injector that is 17 years old and has X hundred hours is a recipie for disaster. Most people talk about plans and then something comes up and they are pushed back and put off. They would require a retune yes but its better to do it now than put it off and forget about it.
Pull off injectors cost less than $200. The top spacer kit from FIC costs $120-$130. It's an oem quality part with known good data available. Screw hacked together data that "works" for fast injectors. Will you need a tune? Yep. anyone who charges you an arm and a leg for an injector swap is a dirt bag. Your tuner should do it on the cheap, I would if I were him.
Hacked together? No. And the fast injectors are $300. You forgot about the electrical connector difference as well. So add on another $50-60 there also. Why is this so hard to understand? The fast is a bosch normally anyway so it is oe quality as well as far as that goes. I dont just sell the parts. I install and tune as well. Id rather have a brand new set of flowmatched injectors preferrably in nearly any build above stock injector limits.
What bosch part number are they?
I am not going to argue with you about gm vs aftermarket etc. You have your opinion and i have facts.
FIC is one of THE MOST TRUSTED companies when it comes to domestic injectors esp for LS. If John says he can resize them and they will work then i believe in him 100% and have even ran them on my own stuff and other customers builds/tunes with zero issues.
Even if all that comes in the set you are still into them for more $$$ . And not all people have a place that cleans injectors locally nor should most places like that be trusted over FIC where that is ALL they do unless they do it as well. $20 for 8 is a little too cheap for new baskets and o rings and complete cleaning.
FIC has several good products. As you can see I plugged one of them. Fast has several good products. The greatest injector in the world is useless without proper characterization data. That data isn't easy to come by.
I said cleaned not rebuilt.
