If I swap my '98 PCM to a 99+ PCM and harness will my fuel gauge still work?
you cannot use a 99+ pcm and harness and have a working fuel gauge.
The 99+ harness is NOT compatible with the vehicle. there are several wires that need to be moved and added to a 99+ harness to make it function properly. Then you need a 0411 pcm with the proper fuel gauge settings enabled in order for the fuel gauge to work.
PM me if you have questions.
