Need help for lowest number of fittings for new setup.
So...I currently have a Fast 90 on my LS1 in my boat. I'm using 'Vette rails now, so the setup was easy. I have a -6 feed and -4 return.
I am now going to a Edelbrock Super Vic with Edelbrock 3638 rails with 3/8" NPT fittings. The Y-Block has 3/8" NPT fittings and the regulator (aeromotive 13129) has -6 AN fittings. I'm trying to get this all put together with the fewest number of fittings possible (keeps cost and possible leak sources lower). The plan is to put one of the regulator ports "direct" to the one rail (so that the rail holds the regulator, so I don't have a lot of mounting surfaces available), and then run a line from the other rail over to the second port. All lines are -6 lines.
Ideas?
Ideas?
