Fuel cap sender quick connect fittings
Old 07-03-2015, 01:21 PM
2000 cam'n SS's Avatar
Default Fuel cap sender quick connect fittings
What kind of power can be had from running a 8an quick connect style connection from the stock fuel hate feed port? Would it be a lot different then drilling a hole and running a bulkhead 8an feed fitting? Just curious of what the 2.5 inches of smaller diameter piping can effect the whole system if it's 8AN out and all the way to the filter then to the rails?
Old 07-05-2015, 09:45 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
We have had no problem at 1000rwhp+ on the stock bulkhead.
The hole in a -8 bulkhead is not as big as you would think anyway.
It is approx. 3/8" depending on the brand of fitting.
Quick Reply: Fuel cap sender quick connect fittings
