87% Injector Duty before the 2-3 shift
Yes racecar only.
N/A only.
Don't keep up with the DA, maybe I need to start.
Really didn't know DA would effect the duty cycle.
What I've read is you don't want no more than 80% duty cycle.
I'm hitting 80% at around 7000 rpm's. Car still pulls to 7500 but starts to miss (pop-pop) then.
Am I running out of fuel at that point.
All the injector charts I go to, say I need atlease 48 lb injectors.
N/A only.
What size injectors are you running now?
The more dense the air the more oxygen present. This requires more fuel.
Do you have a wideband in the car? Was it tuned that high in the rev range?
42 lb injectors.
I have a WB, can't get it to log through HPT yet.
I'll have to look at the tune file to see if it was tuned for that rpm. If I can figure out how to pull up the file.
Still trying to learn all about HPT. I'm really lost. I do all the work on my car, except tuning. This computer tuning, blows my mind. Not computer savy.
I'm old school. LOL.
You'll know more when you get a wideband hooked up. Until then you won't whether your fueling is right, rich, out lean. Then you'll figure out the actual needed duty cycle.
On a dedicated race car, as long as the DA is monitored, I wouldn't worry too much about the duty cycle.
I've got a set of #63 Seimans\Deka injectors which may work for you. They came with my Whipple but I replaced them with id850s.
I live in Collierville and I'll give you a good deal.
