Good 60lb injectors for an lq9 build
Old 07-29-2015, 06:15 PM
Silverfreak's Avatar
Default Good 60lb injectors for an lq9 build
I have an 04 gto with a blown ls1 i am rebuilding it and using an lq4/9 block and will be using 799 head stage 3 ported from AI. The intake will be a Fast 102 lsxr with 102 mm nick Williams throttle body. I was wondering what are a good set of injectors that wont break the bank. I can get a set of obx for 250 used with less than 100 miles on them. Any thoughts ideas?
Old 07-29-2015, 07:13 PM
eaglegoat's Avatar
You don't need 60lb injectors.
Old 07-29-2015, 07:25 PM
drew408's Avatar
I bought my set of 8 name brand 60# from Alan Kennedy aka Injectordude(think its fuelsystems.biz)
Old 07-30-2015, 09:59 AM
I should state the car will be running forged bottom end and either nitrous or turbo, thats why i was asking about 60# injectors. I don't want to get a lean out and damage the engine.
Old 07-30-2015, 02:47 PM
eaglegoat's Avatar
If you run nitrous then run a dedicated fuel system. If you go turbo you'll probably need more than 60s.
Old 07-30-2015, 11:00 PM
kwrench61's Avatar
Deka 80# are the norm for single turbo setups and are affordable
Old 07-31-2015, 07:40 AM
Old Geezer's Avatar
Talking Yep..
Run them at LS fuel psi, [60], and have a 94# inj.....
Old 08-01-2015, 08:08 PM
eaglegoat's Avatar
Originally Posted by Old Geezer
Run them at LS fuel psi, [58], and have a 96# inj.....
Fixed
Quick Reply: Good 60lb injectors for an lq9 build
