thoughts on these injectors and fuel pump
Old 08-30-2015, 08:08 PM
slogo's Avatar
Default thoughts on these injectors and fuel pump
Like title says, I'm putting together a engine but not sure what size injectors
and pump to use, are either one of these any good?
http://www.ebay.com/itm/8-Genuine-Bosch-Fuel-Injectors-110lb-1150cc-110-Corvette-Camaro-LS3-LS7-LS9-LSA-/281751266564?hash=item4199af2504&vxp=mtr
http://www.summitracing.com/parts/aei-18688
thanks for any input
445 ci engine 4.155 bore x 4.100 stroke
ls7 cnc ported heads wcch stage 2 port job and guide repair
fast 102/102 I know that intake will choke it up, will change next time
shooting for 650 fwhp
Old 08-30-2015, 11:16 PM
tadams72's Avatar
Call Jon at Fuel Injector Connection and he will get you setup properly. You don't want to be guessing in this area. Plus he provides the data for tuning the motor to the injector which saves time and hassle.
Old 08-30-2015, 11:26 PM
3.8redbird's Avatar
Those are huge for 650hp NA
You can get away with 60lbs to give you a little room to grow.
FWIW the ZR1 at 650 boosted (consumes more fuel) uses 52lbers.
110lbers would make it a bitch to tune and be less streetable most likely.
Old 08-31-2015, 04:53 PM
slogo's Avatar
Thanks for the replies, I do not know anything about size of injectors, I have started looking into injectors and I saw those, the advertising had the hook in but not quite set yet. So I'm thinking I will look for something like the factory supercharged LS engines
size injectors, are the factory ones good enough? Should I look for any particular
style or squirt pattern, the ones I have listed have 7 little holes in the end of extended
nozzle, whats the extended nozzle for? I'm sure there's plenty more I'm missing.
What about that fuel pump from Summit?
Old 08-31-2015, 08:40 PM
3.8redbird's Avatar
What car?
Old 08-31-2015, 09:18 PM
slogo's Avatar
Going in a 1985 S10 pick up 3300#
T56 trans
Engine mentioned in 1st post
no cam yet
compression will be 11:8 1
dont really want to spin it above 6500
would like it to have 650fw easy horsepower
Old 08-31-2015, 11:17 PM
3.8redbird's Avatar
A 340 would be enough then. Same with 60lbers or 52lbers pull outs. This gives a little wiggle room if you decide spray a lil giggle on top.
The Ls7 102 should use the short injectors like the 52lb zr1 uses.
Old 09-01-2015, 08:58 PM
slogo's Avatar
Thanks again for the info, I have thought about nitrous also but don't have a clue about
that either, but that is for another day. Want to get this thing rolling on it's own power.
Quick Reply: thoughts on these injectors and fuel pump
