99-02 fbody Venturi tube/check valve replacement
Ok I ended up damaging my fuel sender bucket since it would not pull out of my tank, it was swollen/oversized and would not come out so I had to bust the corner to make it slide out..
Anyway I have a spare bucket from another build, only thing is the Venturi tube needs to be replaced on it..
Does the Venturi tube pull straight out, from the bottom? Or can the black Venturi siphone valve be pulled out and replaced with my good tube/valve..
I've circled the Venturi tube and check valve to show what I'm talking about.
I don't want to just muscle through it and break something
