Holley 160 injector o rings to fit ls7 manifold
Im going to be buying 160lb low imp holley injectors to run my tt engine on e 85. Does anybody have a source for orings that will fit the bottom of these injectors and fit an ls7 .580 intake hole? I bought a fast injector spacer kit just for the orings and they are the correct outside diameter but the id is near 9mm and the 83lb low imp injectors I have here are only 8mm I'm assuming the Holley's will be the same size as the 83lb. Anybody know who might have the orings and while we are at it the cheapest place to get holley injectors. Thx
