what to do with fpr vaccum port when NA
With a fpr regulator like the holley efi in the picture, if naturally aspirated and you only need 58 psi of constant pressure EXACTLY like the vette filter/regulator units provide, do you expose the vaccum port portion to the atmosphere or do you plug it?
The reason I ask is that I'm going from a 190 pump to a larger size and I keep reading that a 255+ pump will over power the vette regulator/filter, raising the pressure and altering the afr.
You are getting some bad info.
Leave the vacuum fitting on the regulator open. Read this (page 3, item #15) http://aeromotiveinc.com/wp-content/...9/12/13101.pdf
Only hook the vacuum to your regulator if your tune is vacuum referenced. Meaning adjustments have been made for this.
