remove stock fbody regulator for return system question
Old 12-20-2015, 11:53 AM
SStressin's Avatar
Default remove stock fbody regulator for return system question
so im putting my lonnies dual pump back in. im going to make it a return style system run a -8an feed and use my stock feed as return. quick question the factory regulator is the green looking being hold in by a metal clip that goes into the return plastic line up top. my question is do you also remove the black plastic part that the regulator is housed in? or just pop out the regulator like i did and put the bucket assembly right back in?
Old 12-21-2015, 08:43 AM
ss1
ss1's Avatar
If you take some time cutting, you can remove the entire regulator housing assembly and you'll end up with what is in the attached pics. This way the returned fuel will shoot straight back down in to the bucket, keeping your pumps submersed if your fuel level gets low.
Attached Thumbnails remove stock fbody regulator for return system question-fuel1.jpg   remove stock fbody regulator for return system question-fuel2.jpg
Quick Reply: remove stock fbody regulator for return system question
