injector recomendation??
Ok so im doing the ever so long ls swap into my 71 nova, the project started about 6-8 years ago but got side lined. anyway its back on track. I originally set it up as a carb, but decided to go another route. So my I now have my sbe lq4 6.0, ls3 heads shaved, and a tsp intake , gonna go with holley hp ecu/harness. all the injector calculators ive done assuming 550 flywheel hp say 43lb injectors.....when I look on fleabay prices are all over the place . while I don't want to break the bank I also don't want to do it 2x....anyone got suggestions on where to go for injectors in 43-48lb range?
thanks!
thanks!
Stock LS3 injectors would probably be your cheapest/best buy. Not familiar with the Holley setup but assuming you have not bought it yet I would imagine you can spec the correct injector connector. If so, LS3 injectors will make 550 FWP all day long.
