Will this set up work. And for 1000whp? E85 (fuel pump(s) Q)
Set up above I was running -6 an return and -8an feed with 6#(V6) 83lb dk injectors and -6an fuel rail lines on previous set up. Making 590whp on 93*/640 on 110*/730 on c16*.
I did just switch out all the lines among other things.
what do you think my fuel pumps limits are on E85, power wise? in the set up in the pic.
Thanks in advance.
I will find out when on the dyno in the spring and I run out of pumps.
I might want to switch out the 044 for a 450wal or similar size while it's still winter here.
