Blocking This Hole
Old 03-11-2016, 08:05 AM
Blazeracer's Avatar
Default Blocking This Hole
What is this hole and what's the best way to block it off for boost? I have a bolt in EGR plate for the top hole.
Old 03-11-2016, 07:18 PM
76larkman's Avatar
I believe that is the smog tube hole for egr valve. Rubber plug that tightens with bolt in center. Check parts or hardware store.
Old 03-12-2016, 07:09 AM
Blazeracer's Avatar
Maybe the EGR plate I got is for this hole, then what would block the top hole where the evac pump goes in?
Old 03-15-2016, 03:20 PM
alowerlevel's Avatar
The big hole on the side is for the EGR, the small hole on top behind the TB is for the evap solenoid.
Something like this for the EVAP http://www.ictbillet.com/ls-evap-pur...-manifold.html
And like this for the EGR http://www.ictbillet.com/ls-l33-lq4-...do-551610.html
Quick Reply: Blocking This Hole
