Dual Pumps in LT1 car.
I'm trying to square away my fuel system finally so this year I can lean into my setup and see what she does. I'm quite new to the fuel side of things. The car will be on E85. I'm planning to run twin walbro 485's, Y-ed to a -10 feed and a -8 return. Does anyone have any pictures and information on sticking that all in the lt1 basket? I've done a decent amount of searching and have a slight grasp of what I need, but everything I find is based on LS1 cars. A simple parts list break down would be fantastic as well if anyone has something like that.
The "DIY Dual pump" thread By MM wont load any pictures for me to learn from.
Thanks.
(The car is an LS3 with a PT8847 and a T56 in a 95Z chasis. Hence the LT1 titling.)
Thanks.
Once you get the pump assembly out you won't need any help you will see exactly what needs to be done once it's in your hands. Just order the pumps and a y fitting and get to it. Almost everything but the pumps you can get at the local hardware store. I used these for my y inside the tank they are small and easy to fit in. It's a stainless 3/8 y out of a coke machine they are all over ebay. I bought the whole lot for $10
