1993 Chevy truck 6.0 lq4 swap
Old 04-11-2016, 03:15 PM
EmeraldFlame's Avatar
Default 1993 Chevy truck 6.0 lq4 swap
Can i use the old TBI system with a carb intake and a holley TBI unit like this ? https://www.holley.com/products/fuel.../parts/112-588 And what exactly do i do for mounts?
Old 04-12-2016, 11:42 AM
76larkman's Avatar
Why u want to do that? Just change out fuel pump for correct pressure one in tank. Reconfigure gas lines at motor end hook them up. Ls system is far better than the tbi gm set up.
Old 04-12-2016, 02:06 PM
baronsmith98's Avatar
I have a 92 Sierra with a carbed 6.0 that I run the factory fuel pump. But that Holley throttle body is just for air so you would have to get fuel rails and injectors to make it work. As stated above it would just be easier to upgrade fuel system if staying fuel injected. As for mounts I used dirty dingo.
Old 04-12-2016, 09:39 PM
76larkman's Avatar
TBI GM trucks use 16-20lbs flow pressure pump and you need 58 at the rail. My 88 truck was TBI. It was easy change pump and hook up 2 lines. 1 pressure and 1 return. Unless you have returnless rail.
Quick Reply: 1993 Chevy truck 6.0 lq4 swap
