proxes vs lonnies dual pump
So iv decided to just forget the idea of a single and run a dual pump on my gto. I know proxes kit is newer and lonnies is tested and proven to work. I was wondering what everyone liked better. Also I was curious about the wiring. I know lonnies and proxes both come with wiring harness but to what extent. Is the lonnies wiring as complete as proxes. As far as I can tell the proxes cones with the 340 Instead of the 255. Any other difference.
Gonna be pushing 850 whp max on gas.
Ive had a Proxses for over a year. Dual 340's. The wiring is top notch with a Hobbs and relays. I don't know anything about the other ones. Check Ace Performance, I believe they have a dual that is non return for big power. You will probably have to call them. The Proxses is nice because of the drop in pump assembly. Be sure and use PTFE fuel hose so you don't get the gas smell.
Yeah lonnie say as the failure rate on his system is almost non existent. He did say the dual 255 was the best way to go because the pumps aren't being pushed so hard. What did you do with the rest of your fuel system conan. Upgrade lines and fuels as well?
