lp fix the fuel problem!
Hey fellas,
I have a rather nasty issue. So about a week ago I went to fire up the car and it started then proceeded to die right away. When I went to re-engage, the fuel pump kicked on for a split second (Not long enough to prime) Now it does this every time the key is on! I originally thought it was the pump itself, replaced that with a F98 RaceTronix, same issue. I also replaced the filter to no avail... I checked the relay which seemed fine. I replaced it with a different one and the pump now runs constantly! However there is still no fuel to the rail!. I have disconnected the filter and verified that there is pressure to the filter. Is there some sort of cutoff somewhere further in the line that would stop fuel from getting to the rail? Maybe a security issue, or a regulator further down the line?
I am stumped on this one....
Well, update time. I now have 60 PSI to the Schrader valve, spark, and compression but no running engine! I should have checked this first, but I'm getting P0601 trouble code... It seems I may have a dead PCM. Not cool on a 98 T/A! So I'm thinking that the PCM is not letting the injectors open? I hooked a test light to them and the light stays constant. There is no pulsating going on.
Thoughts? You think I narrowed it down to the root cause?
Restricted User
Check to make sure injectors are pulsing during cranking.
I have this same problem on occasion with one of my LS swapped cars. Pump primes for a split second and shuts off. Car won't start. Its a bad ground for the ECU every single time.
Restricted User
I don't usually bother checking the codes.
I originally had an 06 ECU that I fried. The ground wires for the O2 sensors in 06 are pinned into the ECU, so I had all of the ECU/O2 grounds soldered together with a quick connect terminal on the end that is hooked to a large ground wire thats bolted to the underside of my dash. The ECU lost ground while flashing and quit working. It wouldn't prime the fuel pumps at all after this happened.
I still had the ground issue after swapping to a 2000 ECU. First got it hooked up, pumps would prime for a split second and stop. I noticed that the quick connect for the ground was unhooked, so I fixed the ground and it went away. A couple of times I've accidently hit the ground wire and knocked it loose and my pumps barely prime and the car doesn't start. Everytime I just fixed the ground wire and it started fine.
Re reading that I guess I wasn't clear. I did check the pressure at the schrader which gave me the 60ish psi. I didn't bother to check how long that pressure stayed consistent, but I can tell you I had about 35ish psi when I bled it to release the gauge.
I have ripped the ECM/PCM out and am looking to get it replaced. To my dismay, this part # 77-8212F (16238212) basically does not exist any longer... This is very frustrating.. Does any one know where to get this thing? Or can recommend a competent shop that refurbishes these?
I hear that is a common upgrade, but I wouldn't even know where to start. My fear is I'd do more harm than good. lol I have read that you have to change the internal gas reading mechanism and maybe parts of the cluster?
