Re-entry
Re-entry
Just finishing install of new cam, heads, & IM. 2015 Camaro SS 6.2L. Has taken a lot longer than I hoped. About 3 months not running. Anything special I need to do with fuel system/injectors or anything else? Ex- leave coils unplugged for a few revolutions before starting? Or just button everything up and let 'er rip? Thanks in advance.
Turn the key on and off a few times to prime the fuel lines. Then just crank it and let it idle for a few min to let the oil circulate. Assuming you used assembly lube, that should be all it needs.
As far as fueling goes, you probably should have upgraded your injectors and maybe your fuel pump too
