Ceramic coated fuel rail, ruined o-rings in it, fixable?
Old 06-17-2004, 11:25 AM
C4VetteLS1's Avatar
Default Ceramic coated fuel rail, ruined o-rings in it, fixable?
Ack, i had my dual inlet 97-98 corvette fuel rail (the one with the return line) ceramic coated. I put fuel pressure to it on the car and instantly blew fuel everywhere out of the regulator on the crossover tube. I popped the snap ring off and pulled the regulator piece and looks like it has two o-rings that used to be there before they were melted.
Is the regulator part replacable or should i just get another rail.
Old 06-17-2004, 01:27 PM
Moderator
jimmyblue's Avatar
If it trashed the O-rings, it may also have cooked
the diaphragm inside the regulator body, if there's
that kind of soft parts inside the "pod"; I expect
you should just buy a new regulator and try to
find a way to get the new guts into the pretty
reg shell?
Old 06-17-2004, 01:29 PM
C4VetteLS1's Avatar
Just called dealer, they have the regulator for $60. I ordered one. You think that replaces all the nessesary parts that melted?
Old 06-18-2004, 12:19 PM
John_D.'s Avatar
You might ought to replace the scrader valve too, just to be safe.
Old 06-18-2004, 01:55 PM
C4VetteLS1's Avatar
ohhh never thought of the schrader valve...ill change it out as well
