New fuel tank ideas for my conversion
Old 05-31-2016, 12:14 PM
Grewe02's Avatar
Default New fuel tank ideas for my conversion
I'm currently running an external walbro 255 and a sump fuel cell mounted where my back seat would normally be. I would like to replace it with something more factory-ish, and put it closer to where it's supposed to be between the frame rails. I also dislike climbing through the back window at the gas station to fill it up. Here it is now (yes that vent is now vented):
I like the idea of just purchasing a new tank made specifically for my Jeep, that way I can use the stock filler neck and sending unit. My question is, can I plumb the walbro to the tank sending unit? Or will gravity be working too hard against me?
http://www.ebay.com/itm/JEEP-1978-19...FRDdUh&vxp=mtr
Old 05-31-2016, 01:55 PM
slocaddy's Avatar
Like to see more of your jeep!
Anyways, the consensus is electric pumps are better "pushers" than "pullers". In a perfect set up they will be a little lower than than the tank, at least lower than the fuel level in the tank.
What about sumping the stock tank?
Old 05-31-2016, 02:13 PM
Grewe02's Avatar
Lots of pictures in the thread in my sig
That's pretty much exactly what I was thinking, and in my case since I'm planning on being off camber quite a bit, put a sump in each corner with a collector that goes to the pump. Here's my fancy CAD I came up with, what do you think?
Old 05-31-2016, 03:27 PM
slocaddy's Avatar
One ton, ls cj5!? That thing is sweet!
Here's a pic of mine, I let the cj go, I have a 4.8 for the tj, one day....
Anyway, I like your idea cause it would be uniqe so do that.
Old 06-05-2016, 12:33 PM
Grewe02's Avatar
Thanks It's been a love hate relationship so far haha.
I think I may have found an answer....
https://www.holley.com/products/fuel_systems/hydramat/
Quick Reply: New fuel tank ideas for my conversion
