Throttle Body Blade
Throttle Body Blade
Did a search and didn't find anything conclusive. I'm running Holley HP EFI on a stock truck intake with Deka 60lb injectors. My cam is a LG G5X3. I've heard if you have an aggressive cam you may need to open up the hole in the throttle body blade to get it to idle. Mine won't idle for squat unless I lean on the hot foot ever so slightly. TPS says it's at 5% when I get it to idle by foot.
Any ideas on that? Thanks in advance.
