ls swap fuel pump question
im swapping a turbo 5.3 into my 94 camaro and am a little confused just get a bigger pump and run a return style system or is there some kind of swap to run a non return styl system? any help is appreciated.
Restricted User
No matter what way you slice it, you'll need a return. Regulators work by bleeding off pressure. They have to have somewhere to send it. Typical returnless systems have the regulator built into the tank.
